SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000775
SIMPLE | xf_data_registry | ALL | PRIMARY | | | | 35 | Using where |
SELECT cache_value
Params: 1
Run Time: 0.000176
SELECT post.*
FROM xf_post AS post
WHERE post.post_id = ?
Params: 129528
Run Time: 0.000490
SIMPLE | | | | | | | | Impossible WHERE noticed after reading const tables |
Params: 738f6968c7cd59670def84808a59678a, a:7:{s:12:"sessionStart";i:1714365762;s:2:"ip";s:4:"‘<¦";s:11:"sessionCsrf";s:16:"eUz44HULk8vnZiX2";s:9:"userAgent";s:103:"Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)";s:7:"robotId";s:0:"";s:16:"previousActivity";i:0;s:10:"isIpBanned";a:2:{s:6:"result";b:0;s:7:"version";i:1574415124;}}, 1714369362
Run Time: 0.000327
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, ‘<¦, ‘<¦, XenForo_ControllerPublic_Post, Index, error, post_id=129528, 1714365762,
Run Time: 0.000230
FROM xf_template_compiled
WHERE title IN ('page_nav', 'error', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 15, 2
Run Time: 0.000285
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 3 | Using where |
SELECT title, phrase_text
FROM xf_phrase_compiled
WHERE language_id = ?
AND title IN ('requested_post_not_found')
Params: 2
Run Time: 0.000292
SIMPLE | xf_phrase_compiled | const | PRIMARY | PRIMARY | 106 | const,const | 1 | |
