SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000846
SIMPLE | xf_data_registry | ALL | PRIMARY | | | | 29 | Using where |
SELECT cache_value
Params: 1
Run Time: 0.000240
SELECT post.*
FROM xf_post AS post
WHERE post.post_id = ?
Params: 11578
Run Time: 0.000836
SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT thread.*
0 AS thread_reply_banned
FROM xf_thread AS thread
WHERE thread.thread_id = ?
Params: 94
Run Time: 0.000378
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 52
Run Time: 0.000491
Params: 4509abb527fac71f6fdd656171b8e8e9, a:7:{s:12:"sessionStart";i:1713548525;s:2:"ip";s:4:"…m";s:11:"sessionCsrf";s:16:"cAtyLHDo1ic9Ozm1";s:9:"userAgent";s:103:"Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)";s:7:"robotId";s:0:"";s:16:"previousActivity";i:0;s:10:"isIpBanned";a:2:{s:6:"result";b:0;s:7:"version";i:1574415124;}}, 1713552125
Run Time: 0.000276
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, …m, …m, XenForo_ControllerPublic_Post, Permalink, valid, post_id=11578, 1713548525,
Run Time: 0.000185
FROM xf_template_compiled
WHERE title IN ('page_nav', 'post_permalink', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 15, 2
Run Time: 0.000817
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 3 | Using where |
