Page Time: 0.0849s
Memory: 10.4300 MB (Peak: 12.5885 MB)
Queries (8, time: 0.0039s, 4.6%)
  1. SELECT data_key, data_value
    FROM xf_data_registry
    Run Time: 0.000824
    Select TypeTableTypePossible KeysKeyKey LenRefRowsExtra
    SIMPLExf_data_registryALLPRIMARY   45Using where
  2. SELECT cache_value
    Params: 1
    Run Time: 0.000174
    SIMPLExf_permission_combinationconstPRIMARYPRIMARY4const1
  3. SELECT post.*
    FROM xf_post AS post
    WHERE post.post_id = ?
    Params: 11575
    Run Time: 0.000544
    SIMPLEpostconstPRIMARYPRIMARY4const1
  4. SELECT thread.*
    		0 AS thread_reply_banned
    FROM xf_thread AS thread
    WHERE thread.thread_id = ?
    Params: 94
    Run Time: 0.000478
    SIMPLEthreadconstPRIMARYPRIMARY4const1
  5. SELECT node.*, forum.*
    	permission.cache_value AS node_permission_cache
    FROM xf_forum AS forum
    WHERE node.node_id = ?
    Params: 52
    Run Time: 0.000683
    SIMPLEnodeconstPRIMARYPRIMARY4const1
    SIMPLEforumconstPRIMARYPRIMARY4const1
    SIMPLEpermissionconstPRIMARYPRIMARY35const,const,const1
  6. INSERT INTO `xf_session` (`session_id`, `session_data`, `expiry_date`) VALUES (?, ?, ?)
    Params: 1872a2ebd473c7aac5561419365a1694, a:7:{s:12:"sessionStart";i:1713246103;s:2:"ip";s:4:"Ú=";s:11:"sessionCsrf";s:16:"jdjmP6NTMzqA4sEb";s:9:"userAgent";s:9:"claudebot";s:7:"robotId";s:0:"";s:16:"previousActivity";i:0;s:10:"isIpBanned";a:2:{s:6:"result";b:0;s:7:"version";i:1574415124;}}, 1713249703
    Run Time: 0.000285
  7. INSERT INTO xf_session_activity
    VALUES
    ON DUPLICATE KEY UPDATE
    	ip = VALUES(ip),
    	params = VALUES(params),
    	robot_key = VALUES(robot_key)
    Params: 0, Ú=, Ú=, XenForo_ControllerPublic_Post, Permalink, valid, post_id=11575, 1713246103,
    Run Time: 0.000164
  8. SELECT title, template_compiled
    FROM xf_template_compiled
    WHERE title IN ('page_nav', 'post_permalink', 'PAGE_CONTAINER')
    	AND style_id = ?
    	AND language_id = ?
    Params: 15, 2
    Run Time: 0.000741
    SIMPLExf_template_compiledrangePRIMARYPRIMARY60 3Using where
Included Files (71, XenForo Classes: 50)
  1. index.php
  2. library/XenForo/Autoloader.php
  3. library/XenForo/Application.php
  4. library/Zend/Registry.php
  5. library/Lgpl/utf8.php
  6. library/Zend/Config.php
  7. library/config.php
  8. library/XenForo/FrontController.php
  9. library/XenForo/Dependencies/Public.php
  10. library/XenForo/Dependencies/Abstract.php
  11. library/Zend/Controller/Request/Http.php
  12. library/Zend/Controller/Request/Abstract.php
  13. library/Zend/Uri.php
  14. library/Zend/Controller/Response/Http.php
  15. library/Zend/Controller/Response/Abstract.php
  16. library/XenForo/Model/DataRegistry.php
  17. library/XenForo/Model.php
  18. library/Zend/Db.php
  19. library/Zend/Db/Adapter/Mysqli.php
  20. library/Zend/Db/Adapter/Abstract.php
  21. library/Zend/Db/Select.php
  22. library/Zend/Db/Expr.php
  23. library/Zend/Db/Profiler.php
  24. library/Zend/Db/Statement/Mysqli.php
  25. library/Zend/Db/Statement.php
  26. library/Zend/Db/Statement/Interface.php
  27. library/Zend/Db/Profiler/Query.php
  28. library/XenForo/CodeEvent.php
  29. library/XenForo/Options.php
  30. library/XenForo/Link.php
  31. library/XenForo/Template/Helper/Core.php
  32. library/XenForo/Router.php
  33. library/XenForo/Route/Filter.php
  34. library/XenForo/Route/Interface.php
  35. library/XenForo/Route/ResponseSuffix.php
  36. library/XenForo/Route/Prefix.php
  37. library/XenForo/Route/Prefix/Posts.php
  38. library/XenForo/RouteMatch.php
  39. library/XenForo/ControllerPublic/Post.php
  40. library/XenForo/ControllerPublic/Abstract.php
  41. library/XenForo/Controller.php
  42. library/ExternalExtended/Listener.php
  43. library/XenForo/Input.php
  44. library/XenForo/Session.php
  45. library/XenForo/Helper/Ip.php
  46. library/XenForo/Visitor.php
  47. library/XenForo/Model/User.php
  48. library/XenForo/Permission.php
  49. library/XenForo/Helper/Php.php
  50. library/XenForo/Phrase.php
  51. library/XenForo/Locale.php
  52. library/XenForo/ControllerHelper/ForumThreadPost.php
  53. library/XenForo/ControllerHelper/Abstract.php
  54. library/XenForo/Model/Post.php
  55. library/XenForo/Model/Thread.php
  56. library/XenForo/Model/Forum.php
  57. library/XenForo/Helper/String.php
  58. library/XenForo/Helper/Discussion.php
  59. library/XenForo/ControllerResponse/View.php
  60. library/XenForo/ControllerResponse/Abstract.php
  61. library/XenForo/Helper/Cookie.php
  62. library/XenForo/ViewRenderer/HtmlPublic.php
  63. library/XenForo/ViewRenderer/Abstract.php
  64. library/XenForo/Template/Public.php
  65. library/XenForo/Template/Abstract.php
  66. library/XenForo/ViewPublic/Base.php
  67. library/XenForo/View.php
  68. library/XenForo/Route/Prefix/Members.php
  69. library/XenForo/Route/Prefix/Threads.php
  70. library/XenForo/Debug.php
  71. library/XenForo/ViewRenderer/Json.php
