SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000783
SIMPLE | xf_data_registry | ALL | PRIMARY | | | | 40 | Using where |
SELECT cache_value
Params: 1
Run Time: 0.000182
SELECT post.*
FROM xf_post AS post
WHERE post.post_id = ?
Params: 11573
Run Time: 0.000571
SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT thread.*
0 AS thread_reply_banned
FROM xf_thread AS thread
WHERE thread.thread_id = ?
Params: 94
Run Time: 0.000434
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 52
Run Time: 0.000751
Params: 76dda6db7b006468c627474e6de63841, a:7:{s:12:"sessionStart";i:1713500421;s:2:"ip";s:4:"ʻ";s:11:"sessionCsrf";s:16:"jiYoe-mVPouhjdCF";s:9:"userAgent";s:103:"Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)";s:7:"robotId";s:0:"";s:16:"previousActivity";i:0;s:10:"isIpBanned";a:2:{s:6:"result";b:0;s:7:"version";i:1574415124;}}, 1713504021
Run Time: 0.000258
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, ʻ, ʻ, XenForo_ControllerPublic_Post, Permalink, valid, post_id=11573, 1713500421,
Run Time: 0.000180
FROM xf_template_compiled
WHERE title IN ('page_nav', 'post_permalink', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 15, 2
Run Time: 0.001296
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 3 | Using where |
