SELECT data_key, data_value
FROM xf_data_registry
Run Time: 0.000778
SIMPLE | xf_data_registry | ALL | PRIMARY | | | | 33 | Using where |
SELECT cache_value
Params: 1
Run Time: 0.000212
SELECT post.*
FROM xf_post AS post
WHERE post.post_id = ?
Params: 109697
Run Time: 0.000577
SIMPLE | post | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT thread.*
0 AS thread_reply_banned
FROM xf_thread AS thread
WHERE thread.thread_id = ?
Params: 1738
Run Time: 0.000441
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache
FROM xf_forum AS forum
WHERE node.node_id = ?
Params: 13
Run Time: 0.000479
Params: 08508b1e089e3163ab836c6d89e07c17, a:7:{s:12:"sessionStart";i:1714016154;s:2:"ip";s:4:"’Ý4";s:11:"sessionCsrf";s:16:"UKigFDoF6AxYP5AR";s:9:"userAgent";s:103:"Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)";s:7:"robotId";s:0:"";s:16:"previousActivity";i:0;s:10:"isIpBanned";a:2:{s:6:"result";b:0;s:7:"version";i:1574415124;}}, 1714019754
Run Time: 0.000313
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
params = VALUES(params),
robot_key = VALUES(robot_key)
Params: 0, ’Ý4, ’Ý4, XenForo_ControllerPublic_Post, Permalink, valid, post_id=109697, 1714016154,
Run Time: 0.000207
FROM xf_template_compiled
WHERE title IN ('page_nav', 'post_permalink', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 15, 2
Run Time: 0.000541
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 3 | Using where |
